TwinTurbo.NET: Nissan 300ZX forum - .and if corrroded clean it and apply dielectric >>>
Subject .and if corrroded clean it and apply dielectric >>>
Posted by ZUL8TR on May 12, 2010 at 1:10 PM
  This message has been viewed 113 times.
In Reply To Disconnect and reconnect the MAF connector... posted by gjones on May 11, 2010 at 12:31 PM
Message grease then connect the connector. In fact look into all connectors for corrosion and do the same especially the coolant temp sensor, injectors, throttle position sensor.
Also not effecting your 5000 rpm issue but relates to a proper running engine and often overlooked is the coolant thermostat that could be faulty and not maintaining the correct water temp, this messes up the signal to the ECU. If coolant to cold the ECU will interpret that as still in warm up mode.
ZUL8TR in Orlando,FL
