TwinTurbo.NET: Nissan 300ZX forum - I have a 92 na and 10w 30 works well. I use the castrol>>
Subject I have a 92 na and 10w 30 works well. I use the castrol>>
Posted by ZUL8TR on May 12, 2010 at 1:02 PM
  This message has been viewed 139 times.
In Reply To Oil question posted by Thenumber1zman on May 12, 2010 at 01:14 AM
Message high mileage and have 86K on the odo. Unless your car has excessive bearing clearance the 10w 40 is not necessary. As far as syn oil you want to be sure the seals are not presently leaking because the syn oil will clean any buildup behind the seals and leakage could occur that may or may not go away. Syn oil will soften the seals somewhat but it is speculative if the leakaqe will go away. If the engine has excessive mileage I would stick with the non syn.
As noted use the search
ZUL8TR in Orlando,FL
