TwinTurbo.NET: Nissan 300ZX forum - need help won't start. seems as if no fuel getting
Subject need help won't start. seems as if no fuel getting
Posted by FASTESTZX on May 11, 2010 at 10:19 PM
  This message has been viewed 79 times.
Message I was changing out the water pump, thermostat, overdrive crank
pulley, fan clutch elimination , hard radiator lower, and
mishimoto radiator. I disconnected the electrical connection
without disconnecting the battery cables!! I forgot that when
I plugged it in. Did I screw it up? I cranks but won't fire.
It seems like it is not getting any fuel flow. When I turn
the key it does not seem like the fuel pump is pressurizing
the gas tank. Also when the key is on accy the turn signals
don't function. Is there a fuel pump relay or some reset
function? It should fire but just cranks and cranks w/nada
