TwinTurbo.NET: Nissan 300ZX forum - Cold water leaking on passenger side when A/C is ON
Subject Cold water leaking on passenger side when A/C is ON
Posted by robsheer on May 11, 2010 at 1:18 AM
  This message has been viewed 145 times.
Message Today I started seeing cold water streaming down on the passenger side while my air conditioner was turned on. It stopped as soon as I turned off the A/C. It's repeatable everytime I turn on the A/C again. It takes a few minutes to get going. It starts as a gurgling sound, then all of a sudden a pretty good stream of very cold water starts dripping on the passenger floor.
Has anyone seen this before and can point me in the right direction? I will be checking the evaporator drain, but I see some water(small puddle) under the car which suggests that it's draining to the outside, maybe just not draining fast enough. Any help would be greatly appreciated!!
Also, does anyone know the normal refrigerant pressure (in PSI) for both the HIGH pressure side and LOW pressure side?
Thanks!
