TwinTurbo.NET: Nissan 300ZX forum - I had oil slightly pooled in the exhaust side of the
Subject I had oil slightly pooled in the exhaust side of the
Posted by xteam300tt on May 10, 2010 at 1:58 PM
  This message has been viewed 253 times.
In Reply To What would the downpipes look like? posted by mvtz on May 10, 2010 at 01:22 PM
Message turbo . pull off the dp and look inside the turbos , inspect the plugs as well . if all looks good then it may be coming through the pcv's . did you remove / replace the two factory vent lines (pcv) that come off the front of those valve covers ? iv heard of people replacing those lines with regular lines and you cant do that . you must retain the restrictor in those lines to help keep the oil in .
