TwinTurbo.NET: Nissan 300ZX forum - Re: auto transmission
Subject Re: auto transmission
Posted by txq45 on May 09, 2010 at 7:36 PM
  This message has been viewed 88 times.
In Reply To auto transmission posted by minivandan on May 09, 2010 at 10:50 AM
Message Don't have to prime them just make sure you have plenty of fluid in the converter. Does seem like a pressure problem.
Draning fluid then refilling has in some cases cases pieces to become clogged in transmission. I assume your fluid was pink and not dark or a burnt color before changing.
Dropping the valve body and doing a circuit test will give you more info, but the slipping in all gears is a real problem.
Nistune Dealer www.aaa-hiperformanceauto.com
Transmissions for TT, Skyline, 240 built for HP over 1000
