TwinTurbo.NET: Nissan 300ZX forum - here is why compressors blow freon out
Subject here is why compressors blow freon out
Posted by de944 on May 09, 2010 at 12:22 PM
  This message has been viewed 135 times.
In Reply To AC question, if the compressor blows and all freon posted by RT on May 08, 2010 at 02:21 PM
Message There is a valve on the back of the compressor. If your high side head pressure is too high, a check valve opens to relieve the pressure into the atmosphere. It is almost imposible for a compressor to blow or leak freon from the back side. If there was a large rush of freon and a very noisy strange sound, then it was probably your pressure valve. Usualy a compressor that fails will leak freon from the front clutch seal or just plain seize up. Before you condemn the compressor you will need to find the leak. Generaly the relief valve tripping is due to an incorrect freon charge, blocked/dirty condensor, or malfunctioning condensor cooling fan. Save yourself some money and do some further troubleshooting first. Hope this helps.
