TwinTurbo.NET: Nissan 300ZX forum - The belt line up and cog count looks ok.>>>>
Subject The belt line up and cog count looks ok.>>>>
Posted by ZUL8TR on May 09, 2010 at 8:32 AM
  This message has been viewed 170 times.
In Reply To idle jumps/bounces after belt slip posted by devastator357 on May 09, 2010 at 02:25 AM
Message So look to the CAS and the CAS sensors at the rear of the heads.
Based on the compression numbers the valves appear to be ok. To verify follow up the compression test with a squirt of oil in each cylindere and if numbers go up the valves are most likely not the issue but some air loss there would indicate the rings are somewhat worn. The degree of increased compression will provide a measure of the ring wear.
According to this link TT perfect compression is 174 (per Ash) and 121 min with 14 psi max difference from high to low.
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=868155&words=compression%3a%3atest ]
So a little wear is present.
ZUL8TR in Orlando,FL
