TwinTurbo.NET: Nissan 300ZX forum - Front high pressure PS line removal, how?
Subject Front high pressure PS line removal, how?
Posted by GODzxLLA on May 07, 2010 at 3:16 PM
  This message has been viewed 81 times.
Message I have read every search post and really have no idea how you can remove the two hard lines easily .I am assuming the front one is the high pressure line that are in the brackets mounted together that run across the front of the car. Mine has a major leak and crack in the 45 degree angle when it reaches the bottom of the car from the reservoir for the hicas. I read someone changed theirs in five minutes. No way in hell ! I have mine on ramps and stil see no way !You cannot get to any of the fittings. Do you disconnect them at the hicas pump up top and then on the PS pump. I cannot not see the connections. The post I did see had no pics anymore to view. Thanks !
