TwinTurbo.NET: Nissan 300ZX forum - Re: Are you having issues with overheating...
Subject Re: Are you having issues with overheating...
Posted by carlosjavierz on May 07, 2010 at 9:11 AM
  This message has been viewed 217 times.
In Reply To Are you having issues with overheating... posted by Z DNA on May 07, 2010 at 08:40 AM
Message :or seeing any evidence of coolant leaking? Is there a lot of play in the pulley? Why do you suspect it may be going out?
i accidentally ran the car w/ low water and i could hear the pump, never got to the red line....but it was hesitant while running......filled it later.....noticed water dripping down the middle of the block from the water pump area.....but later stopped.....the main problem now is that it is delaying while running on D (automatic) to shift....this never happened before.....but the temperature remained at middle........your hints are quite helpful.....
