TwinTurbo.NET: Nissan 300ZX forum - Re: Re: so confused
Subject Re: Re: so confused
Posted by Thenumber1zman on May 03, 2010 at 12:30 AM
  This message has been viewed 53 times.
In Reply To Re: so confused posted by CmyZ on May 02, 2010 at 10:30 AM
Message I know that the injector plug and the coil plugs are good. I can switch them with other cylinders and they work just fine. So I think it must be the injector right? I check the injector with the ohm meter and it showed 12 ohms. So what else could it be? I know that the injector tested good but could it be a farther problem other than the fact that it test good that way.. ie: spray, or something else? HELP my car is almost running right... lol :) What did you mean by check grounds? like where?
