TwinTurbo.NET: Nissan 300ZX forum - Re: so confused
Subject Re: so confused
Posted by CmyZ on May 02, 2010 at 10:30 AM
  This message has been viewed 70 times.
In Reply To so confused posted by Thenumber1zman on May 01, 2010 at 01:59 PM
Message First check voltage at coil pack harness in question and the injector harness. If that is good, then switch the coil pack with another one from a known working cylinder that shows the rpm drop. That way you will rule out a bad coil pack, if no change, check your injector,ohm it out, it should read between 10 - 14 ohms. If it does not ohm correctly replace injector, but before make sure your grounds are clean and properly bolted.
