TwinTurbo.NET: Nissan 300ZX forum - Time to carry my weight: Relay locations
Subject Time to carry my weight: Relay locations
Posted by DKaway on May 02, 2010 at 9:36 AM
  This message has been viewed 220 times.
Message I had an intermitten problem that involved the cigarette lighter, front wipers and automatic A/C pod DISPLAY NUMBERS.
Search my scrfeen name to find my posts about this problem (started back in Nov 2009)
That told me there was one problem in common, when one came on, they all came on. I posted questions and everyone sugested to check relays, but never said where, besides the obvious ones.
well, the fuse panel by the clutch pedal has relays BEHIND the fuse block (attached to the fuse block).
two screws remove the fuse block from the wall (very esy to get to), you might have to disconnect some of the cable connectors to get behind the fuse block and check/remove/replace the appropriate relay.
my accessory relay that feeds the front wipers, a/c pod NUMBER DISPLAY, and cigarette lighter was bad. removed it applied 12v to terminals 1 and 2 heard the click, the first time and no other clicks after the first try.
hope this helps some others here.
