TwinTurbo.NET: Nissan 300ZX forum - Well, not sure if it really is an issue with the connector.
MixManMash
on May 01, 2010 at 1:12 AM
IMO you should diagnose the issue with the connector
posted by Ashman2k2
on April 30, 2010 at 05:37 PM
I could have the idle screw all the way in or out and it will run the same with AAC connected. The AAC actually helps it to keep running while the screw is in. Going to do further diagnosing tomorrow and I will report back.
New Theory Regarding Idling Issue.
MixManMash
11:15:35 04/29/10
No.
ZiNnYc
15:46:51 04/29/10
Well, there isn't red top there any more. Put in a new battery, no difference.
MixManMash
19:55:52 04/29/10
Reason I ask about the AFC is
ZiNnYc
23:44:05 04/29/10
Re: New Theory Regarding Idling Issue.
MaxxAction
16:54:49 04/29/10
Nismo 555s as per my profile. They test out fine as well. (n/m)
MixManMash
19:32:37 04/29/10
canyoncarver
19:39:57 04/29/10
The thing is, that it performs fine. just doesn't want to idle well, especially
MixManMash
19:47:27 04/29/10
does your mulitmeter show ~14v across the battery
canyoncarver
21:22:13 04/29/10
Yup. 14.4V now. (n/m)
MixManMash
23:26:59 04/29/10
Update:
MixManMash
23:41:54 04/29/10
Did you install the EPROM?
ZiNnYc
23:46:26 04/29/10
Yes, I have tried a different EEPROM. no difference.
MixManMash
08:19:47 04/30/10
I don't understand why you think a small boost leak
canyoncarver
06:46:29 04/30/10
Because it's the same small boost leak I had last year when the car was running fine. And it's in a
MixManMash
08:22:21 04/30/10
While you are right in that it's probably not due to a minor
ZiNnYc
09:31:25 04/30/10
It's in such a bad place, that the amount of labour it would
MixManMash
11:48:47 04/30/10
Re: It's in such a bad place, that the amount of labour it would
canyoncarver
14:14:25 04/30/10
Passenger side intake valve cover. It picked up some
MixManMash
16:41:15 04/30/10
Well, is it your DD? Sounds like an afternoon to me. (n/m)
ZiNnYc
17:25:11 04/30/10
Not my DD. But with all the effort it would take to pull
MixManMash
01:08:39 05/01/10
lol
ZiNnYc
13:06:09 05/01/10
lol. I'm saying I'd rather put the effort in. Yes it's
MixManMash
13:53:58 05/01/10
things to do:
ZiNnYc
09:38:54 04/30/10
Did try another ECU with another EPROM. Not difference.
MixManMash
11:46:33 04/30/10
How does it behave with the AAC connector disconnected?
Ashman2k2
12:19:43 04/30/10
I checked the butterfly valves and they are in sync /
MixManMash
16:42:26 04/30/10
Forgot, with the AAC connector disconnected, the idle drops
MixManMash
16:45:02 04/30/10
Ashman2k2
17:37:42 04/30/10
Well, not sure if it really is an issue with the connector. -
MixManMash
01:12:10 05/01/10
Disconnect the yellow AAC valve connector and set your idle
Gordo 93TT Daytona
19:58:07 05/02/10
Yet another update:
MixManMash
16:21:36 05/01/10
Do you have your recircs?
ZiNnYc
11:37:04 05/02/10
My recircs were shot (goose honk). So I replaced them with
MixManMash
15:20:12 05/02/10
Were your plugs oily or sooty?
canyoncarver
12:20:40 05/02/10
The plugs were sooty, not wet. And there was a smell of
MixManMash
15:19:23 05/02/10
Have you checked fuel preesure and does it hold
canyoncarver
22:27:08 05/02/10
I have checked fuel pressure. It is in spec. My guess with
MixManMash
09:00:40 05/03/10
