TwinTurbo.NET: Nissan 300ZX forum - Did you use the lexan/aluminum pop can trick?
Subject Did you use the lexan/aluminum pop can trick?
Posted by Poppe on April 30, 2010 at 9:27 AM
  This message has been viewed 77 times.
In Reply To crankshaft seal posted by Mr. Magoo on April 30, 2010 at 08:23 AM
Message If so, I think you should be fine. Secondly, if it tapped in easily, you should have nothing to worry about. If you had to hit it a bunch and the front lip of the seal looks slightly messed up (rolled), you may want to back it out.
