TwinTurbo.NET: Nissan 300ZX forum - Well, there isn't red top there any more. Put in a new battery, no difference.
Subject Well, there isn't red top there any more. Put in a new battery, no difference.
Posted by MixManMash on April 29, 2010 at 7:55 PM
  This message has been viewed 199 times.
In Reply To No. posted by ZiNnYc on April 29, 2010 at 03:46 PM
I've had the Selin unit for a while. Yes it is set to AVG. This issue only came up after storing it.
I had an AFC which was removed prior to installing the Selin setup.
I am going to check out the coolant temp sensor with Nissan Datascan.
The connectors are clean and I have an extra set of known good MAFs that I borrowed to test out.
The IACV was cleaned out last year. Boost leak testing showed a very small leak which shouldn't cause this problem, as I mentioned previously.
There are no codes. The O2's should be fine as they are fairly new. However, I will check the readings using Datascan and will report back.
