TwinTurbo.NET: Nissan 300ZX forum - Re: New Theory Regarding Idling Issue.
Subject Re: New Theory Regarding Idling Issue.
Posted by canyoncarver on April 29, 2010 at 7:39 PM
  This message has been viewed 124 times.
In Reply To New Theory Regarding Idling Issue. posted by MixManMash on April 29, 2010 at 11:15 AM
Message Agreed with the "no". A bad battery connection or bad connection elsewhere can cause idle problems. One of the basic maintenance / troubleshooting things to do on these cars is to clean ALL of the electrical connections. This should include the battery terminals and make sure the sub-system power wire coming off of the battery is clean and in good condition. If your battery cables are original, or over 10 years old, replacing them couldn't hurt.
If it is an electrical problem causing your idle issues, you could check the power supply to the ECU and other components to see if the voltage is low, ie: if you don't have a full 12v going to the ECU, injectors, coipacks, etc... you will have performance problems. Alternator harness and ground connections are equally important.
Bottom line...... if you have 12v power going to everywhere it needs to go, it's not likely an electrical problem.
