TwinTurbo.NET: Nissan 300ZX forum - My thoughts exactly,
HighPsi (NorCal)
on April 29, 2010 at 3:31 PM
Tuning for injectors that big with an afc is a bad idea.
posted by Wright (Ca)
on April 29, 2010 at 01:27 PM
using it for a dual maf setup is one thing, trying to correctly control engine advancement and a/f's by tricking the ecu is a recipe for catastrophic failure.
Injector question
300zxNA2TT
11:16:25 04/29/10
If you engine is flooding then your ECU tune is incorrect.
Eric(FL)
11:20:38 04/29/10
has ecu been upgraded for 740cc? 740 would be the
ZonaZ
11:21:17 04/29/10
Yes my ecu is programmed for 740. Unless the guy programmed
300zxNA2TT
11:29:10 04/29/10
Did you install the injectors yourself? If so, was the fuel
Eric(FL)
11:45:06 04/29/10
If you have a chip you should update your profile.
Josher
11:54:51 04/29/10
Did they check for pinched orings? (n/m)
Woody75 (Denver)
11:35:11 04/29/10
2nd (n/m)
aliaZ
11:58:26 04/29/10
I dont think so ? (n/m)
300zxNA2TT
12:04:53 04/29/10
No I had the motor built by a shop and a "friend".
300zxNA2TT
12:04:06 04/29/10
I'd start with trying an EEPROM from a tuner with a good
Wright (Ca)
12:31:41 04/29/10
2nd, your eprom is not something to be left to chance
12:42:10 04/29/10
Re: I'd start with trying an EEPROM from a tuner with a good
300zxNA2TT
13:06:18 04/29/10
Wright (Ca)
13:27:18 04/29/10
My thoughts exactly, -
HighPsi (NorCal)
15:31:56 04/29/10
