TwinTurbo.NET: Nissan 300ZX forum - Did you install the injectors yourself? If so, was the fuel
Subject Did you install the injectors yourself? If so, was the fuel
Posted by Eric(FL) on April 29, 2010 at 11:45 AM
In Reply To Yes my ecu is programmed for 740. Unless the guy programmed posted by 300zxNA2TT on April 29, 2010 at 11:29 AM
Message rail pressure tested before install to check for leaks or pinched o-rings as Woody said? Did the problem start as soon as you installed the injectors?
later,
eric
