TwinTurbo.NET: Nissan 300ZX forum - Problem starting, ? on Clutch switch.
Subject Problem starting, ? on Clutch switch.
Posted by CoHPhasor on April 28, 2010 at 10:41 PM
  This message has been viewed 413 times.
Hi guys.
I ran into a problem this evening.
When I got in the car to leave I had to press the clutch 3 times before it would start.
This has occurred a few times over the last month. (press once, twice, each time varied)
I really believe it's the clutch switch as it doesn't crank, the headlights seem fine, and it's not "clicking/etc like a low batt would. (AND once pedal is pressed right it fires right up)
While out it refused to start. I tried dozens of times.
I even crawled down there and hand pressed it.
I had my wife with me and we were able to bump start it. After driving home, I turned it off, then she fired RIGHT back over! grrr
The only thing I can think is the switch is going bad and I may need to temporarily bypass it just in case.
To bypass it, do I need to simply make a connection between the 2 wires to the switch?
