TwinTurbo.NET: Nissan 300ZX forum - Re: Varying clutch pedal feel/pressure '91TT
Subject Re: Varying clutch pedal feel/pressure '91TT
Posted by Greg D. (Specialty-Z) on April 26, 2010 at 8:33 PM
  This message has been viewed 82 times.
In Reply To Varying clutch pedal feel/pressure '91TT posted by w8lifter4 on April 26, 2010 at 05:50 PM
Message The pressure being different is probably due to a ridge on the trans front cover. The T.O. bearing collar is probably catching on it sometimes. It could also be the T.O. bearing collar is rounded where the clutch fork fits allowing the collar to be pressed uneven.
It sounds like your clutch master is failing now and it is a good idea to change the slave at the same time.
