TwinTurbo.NET: Nissan 300ZX forum - Local Z owner clutch woes, need serious advice.
Subject Local Z owner clutch woes, need serious advice.
Posted by ZiNnYc on April 26, 2010 at 9:25 AM
  This message has been viewed 145 times.
Message This is the third clutch going in within a year.
All clutches have been installed properly,
pedal adjusted properly. All clutches exhibit
signs of slipping after 4K worth of driving.
After driving it spiritedly, car lost hydraulic
pressure. Can't get into gears without
immense effort and pumping the loose pedal.
Fluid bled till the cows came home. SC intact.
Pivot ball looks intact upon inspection. Scared
to drop tranny again just to find another
burnt up clutch and in this case a possible
bent in pressure plate. All prominent brands
of clutch have been used, no cheap stuff.
Any ideas as to wat the underlying issue is
here? This time, it looks like thw pressure
plate (zero hydraulic loss/issue), but why this
many problems with a single tranny? Need
some outside the box thoughts here.
