| Subject |
From underneath when doing an oil change |
| Posted by |
ConVerTT on April 24, 2010 at 8:07 PM |
This message has been viewed 86 times. |
| In Reply To |
im wondering how... posted by 300zx_2+2 on April 24, 2010 at 08:03 AM |
| Message |
1) drain the oil 2) remove the oil drain line from the turbo and push it out of the way (2 x 12 mm bolts, plus an 8mm driver to loosen the hose clamps on the rubber connector) 3) remove the oil pressure sensor from the oil tree (optional - depends how big your hands are)Now you should have plenty of room.
| Follow Ups |
Post a Followup |
