TwinTurbo.NET: Nissan 300ZX forum - If you have a worn out transmission mount or
RICH1
on April 23, 2010 at 8:11 AM
Driveshaft Issues after Z1 1-piece install on a 93 Z 2+2
posted by dwayne
on April 22, 2010 at 11:26 PM
rear differential bushings, that adds to the problem.
dwayne
23:26:01 04/22/10
#3
ZLover4Life
23:33:00 04/22/10
My assumption is that it was due to u-joint operating angles
Ashman2k2
21:13:27 04/27/10
#3
Draker (Eugene, OR)
23:41:37 04/22/10
#3 ... Had you "searched" and read up on one-piece
zellamay
00:51:26 04/23/10
I have talked to many Z'ers with the one peice Z1 Platinum
KongZTT GT28RS MD
01:10:36 04/23/10
Why? Is it that feeling of relief when you get it
zellamay
13:51:28 04/23/10
There is a procedure to properly install the driveshaft
KongZTT GT28RS MD
01:13:49 04/23/10
it involves measuring the runout, and I believe it only
05:08:31 04/23/10
There are manufacturing tolerances in every part.
zellamay
13:39:45 04/23/10
hmmm, so you're saying the vibration is the result of the
20:17:03 04/23/10
send it back for another, its obviously flawed (n/m)
Z32TT-R
03:25:19 04/23/10
EXACT same issue here, although mine is with an EPRacing
04:57:57 04/23/10
Re: EXACT same issue here, although mine is with an EPRacing
Tech@EPR
05:51:49 04/23/10
I understand the differences. I must not have received bolts
07:49:49 04/23/10
Re: I understand the differences. I must not have received bolts
Tech@EPR
09:33:35 04/23/10
Re: Driveshaft Issues after Z1 1-piece install on a 93 Z 2+2
ak420
07:02:10 04/23/10
how would you describe the shudder?
ZiNnYc
07:05:01 04/23/10
I had problems with a 1-Piece, and went back
Trailboss
07:08:19 04/23/10
this install requires only about 3 different
KasbeKZ(VA)
07:21:12 04/23/10
If you have a worn out transmission mount or -
RICH1
08:11:59 04/23/10
bryan@Z1
11:38:31 04/23/10
Thanks for all the suggestions...Dwayne
dwayne
12:13:16 04/23/10
I've got a 2+2 with the Z1 DS...
xpwarrior
19:14:45 04/26/10
