TwinTurbo.NET: Nissan 300ZX forum - Any ECU for a TT will be OK to test out your engine build.
Subject Any ECU for a TT will be OK to test out your engine build.
Posted by Gordo 93TT Daytona on April 22, 2010 at 9:26 PM
  This message has been viewed 97 times.
In Reply To Background posted by NolimitZ32 on April 21, 2010 at 09:43 PM
Message All you want to do is see if the engine will idle and accelerate under light load. It is unlikely timing is your issue. Heck, you can almost time an engine at idle by ear. Just twist the CAS until the engine smooths out. It will be within a few degrees of 15' BTDC. Certainly close enough to eliminate the problems you are having.
_________________________________________________
