TwinTurbo.NET: Nissan 300ZX forum - I guess a leaking fuel adapter/injector would cause low
inf
on April 21, 2010 at 11:21 PM
Ok, all of what you said is obvious.
posted by inf
on April 21, 2010 at 10:42 PM
vacuum since the engine is trying to maintain the lost pressure...
What would cause low vacuum?
inf
13:10:09 04/20/10
Timing being off..
Draker (Eugene, OR)
14:17:38 04/20/10
I know the timing is good...
inf
22:15:07 04/20/10
Well you've done a compression test..
Draker (Eugene, OR)
00:19:13 04/21/10
as far as i know...
inf
02:15:01 04/21/10
Re: as far as i know...
canyoncarver
06:37:00 04/21/10
inf
22:42:49 04/21/10
occasionally the vacuum will be in the proper range and hold
inf
22:46:21 04/21/10
Well, depending on where your idle is..
Draker (Eugene, OR)
23:30:33 04/21/10
I used the boost leak tester and had it hit 5 psi
inf
01:57:52 04/22/10
Thank you
inf
13:15:55 04/22/10
I guess a leaking fuel adapter/injector would cause low -
inf
23:21:50 04/21/10
Re: Ok, all of what you said is obvious.
canyoncarver
06:49:23 04/22/10
Thank you
inf
13:04:07 04/22/10
