TwinTurbo.NET: Nissan 300ZX forum - Had the same issue
Subject Had the same issue
Posted by Zbullet on April 21, 2010 at 9:11 PM
  This message has been viewed 51 times.
In Reply To Fuel leak from rear of engine posted by Sidewinder007 on April 19, 2010 at 06:42 PM
Message The hose connecting my fuel pressure regulator was loose. Fuel was dripping down the engine at a steady rate in the same location you described.
Unfortunately the clamp was rotated making the fix more difficult than it needed to be. I pulled the plenum anyhow and replaced all the fuel lines and clamps. Used hex head bolts to make tightening them down the road a bit easier.
The bolts are "M4".
Good luck!
