TwinTurbo.NET: Nissan 300ZX forum - it's a good idea to check it before and after...
Subject it's a good idea to check it before and after...
Posted by Paulym1111 on April 21, 2010 at 4:50 PM
  This message has been viewed 89 times.
In Reply To Is it a MUST to check the timing after a TB change? (n/m) posted by wolftg (DEN) on April 21, 2010 at 03:42 PM
Message It helps to verify that your belt is on correctly because your timing shouldn't change if you didn't mess with the CAS. If the belt is installed incorrectly, the timing will be off. That being said....it's smart to do, but you don't have to.
