TwinTurbo.NET: Nissan 300ZX forum - Re: PTU CAS
Subject Re: PTU CAS
Posted by Jordan[z32] on April 21, 2010 at 12:01 PM
  This message has been viewed 231 times.
In Reply To PTU CAS posted by dubya86 on April 16, 2010 at 01:23 PM
Message :the PTU (Power Transistor Unit) gets a signal from the computer telling the coil when to fire. The early style PTUs were recalled because of premature failure do to heat, they have aluminum tops, looks like this.
:[ http://dta-motorsport.com/used/ptu.jpg ]
:And the newer style looks like this.
:[ http://www.z32photoguide.com/ptu.html ]
:the CAS (Crank Angle Sensor) tells the computer where the Crankshaft is so that it knows what part of the engine cycle is going on. seen here.
:[ http://www.z32photoguide.com/images/3sensorloc.jpg ]
:I would check your connections at both the PTU and CAS... and to be honest you seem to be having the same problem I am having, but those where the things everyone has said to check first.
Ok thanks alot for the help i'll try it out
