TwinTurbo.NET: Nissan 300ZX forum - Re: A restrictor is a flow metering device
Subject Re: A restrictor is a flow metering device
Posted by zxrider45 on April 20, 2010 at 6:18 PM
  This message has been viewed 85 times.
In Reply To A restrictor is a flow metering device posted by Zarcasm(Hfd, CT) on April 20, 2010 at 05:56 PM
Message Ok well i changed my intake pipes and i changed to new hoses that we
installed the bristles into but not the restrictor. And since then i noticed a
slight miss at a steady rpm around 2000 after a cold start and then
maybe after about 5 mins of driving it would be gone. Well then a month
or 2 down the road " a couple weeks ago" i was doin about 80 on 295
and my z just shut off. So i pulle over and i thought the cas plug fell out
cuz the clip is broken from the engine swap. So i pushed it in," it wasnt
even out" and it started right back up and went about 5 ft and died
again. Later we found out the ecu stopped controlling the fuel pump. so
Luckily i had an extra one from the swap so we put it in and everything
was all good. Well now that slight miss is all the time when not
accelerating. And im running extremely rich. And when i accelerating it
stumbles a lil. Any ideas lol? Could be that hose?
