TwinTurbo.NET: Nissan 300ZX forum - Re: If a belt is squealing is it safe to assume it needs to be
Subject Re: If a belt is squealing is it safe to assume it needs to be
Posted by Marty1Mc on April 20, 2010 at 6:13 AM
  This message has been viewed 130 times.
In Reply To If a belt is squealing is it safe to assume it needs to be posted by pocheeyo on April 20, 2010 at 03:53 AM
Message All depends, if the belt has been squealing, it may be toast. The squealing is due to slippage. That slippage causes the surfaces to burn a little and harden, requiring additional tightness to get it to grip. If the belt has squealed for some time, you may want to replace it.
A test is pretty simple, turn the belt at a point between two pulleys and see if it turns 90 deg. If it turns way beyond, it's probably too loose.
