TwinTurbo.NET: Nissan 300ZX forum - 2nd! This is the auto trans oil cooler
Subject 2nd! This is the auto trans oil cooler
Posted by Draker (Eugene, OR) on April 18, 2010 at 11:07 PM
  This message has been viewed 78 times.
In Reply To If you are talking about the 2 small hoses... posted by scottyfender on April 18, 2010 at 09:41 PM
Message It's built into the radiator. Set the transmission fluid to the correct level, and check when the engine is running and in N or P. If you check it with the engine off.. the level is going to be very high.
I believe there is a transmission diagnostic you can run to diagnose it. Likely if it's slipping then you've got a clutch pack going out. What gear does it slip in?
Either way, if it's the clutch packs, it's going to be rebuild or new/used transmission swap. Or 5 speed swap..
