TwinTurbo.NET: Nissan 300ZX forum - Your compression would be lower.
Subject Your compression would be lower.
Posted by Draker (Eugene, OR) on April 18, 2010 at 12:14 AM
  This message has been viewed 94 times.
In Reply To New idea, but still missing on 2 & 6. posted by dubya86 on April 17, 2010 at 10:40 PM
Message I mean, it's low already. You can do a running compression test to verify. Compression number are going to be different when doing a compression test with the engine running(Low).
What I would be looking for is when you rev up I would expect to see your compression drop way low if the intake valves were indeed stuck closed or partially closed.
When you are doing a static compression test, what are your numbers on the first stroke? It should be at least half of the final result. So around 75psi.
