TwinTurbo.NET: Nissan 300ZX forum - Re: I would suspect the starter relay.
Subject Re: I would suspect the starter relay.
Posted by NewbieJohn on April 17, 2010 at 9:56 PM
  This message has been viewed 1061 times.
In Reply To I would suspect the starter relay. posted by Draker (Eugene, OR) on April 17, 2010 at 09:10 PM
Message :But here are the possible issues.
:Battery cables
:Starter relay
:Ignition switch
:Clutch switch
:Starter
:Starter Solenoid
:Like I said in the topic I think it's probably the starter relay. Just tap it with a screwdriver and give it another try. Since its in a parking lot you probably can't get under it to jumper the starter to 12v.
:See where this gets ya.. I'm sure others will have a few more ideas.
Thank you. I'll focus on the starter relay. The car is way TOO low to get to the starter. I thought about push starting, but the parking lot is flat.
Thanks,
John
New Jersey
