TwinTurbo.NET: Nissan 300ZX forum - PTU CAS
Subject PTU CAS
Posted by dubya86 on April 16, 2010 at 1:23 PM
  This message has been viewed 569 times.
In Reply To Re: did you actually check for spark? posted by Jordan[z32] on April 16, 2010 at 01:05 PM
Message the PTU (Power Transistor Unit) gets a signal from the computer telling the coil when to fire. The early style PTUs were recalled because of premature failure do to heat, they have aluminum tops, looks like this.
[ http://dta-motorsport.com/used/ptu.jpg ]
And the newer style looks like this.
[ http://www.z32photoguide.com/ptu.html ]
the CAS (Crank Angle Sensor) tells the computer where the Crankshaft is so that it knows what part of the engine cycle is going on. seen here.
[ http://www.z32photoguide.com/images/3sensorloc.jpg ]
I would check your connections at both the PTU and CAS... and to be honest you seem to be having the same problem I am having, but those where the things everyone has said to check first.
*82 Degrees, sun is shining, T-tops are off, windows are down, cruising down the highway at 80 MPH, and the only music I can here is coming from my exhaust... this is what owning a Z32 is all about.*
