TwinTurbo.NET: Nissan 300ZX forum - At my wits end
Subject At my wits end
Posted by dubya86 on April 15, 2010 at 5:06 PM
  This message has been viewed 98 times.
Message Last weekend my car was running just fine, all this week it has been missing on cylinders 2 & 6, as in not firing at all, regardless of pulling coil connection or removing injector connection.
I have checked ohms on the injectors (all within spec), checked ohms on the coils (all within spec), switched coils to cylinders I know work (still not firing on 2 or 6), checked the PTU connections (I have continuity to all the coils, cleaned to make sure of good connection), have checked the CAS (cleaned connectors, no other issues there)... I did pull one of the coils off and check the spark, it was sparking but did not really seem like a strong spark, was more a bunch of little sparks...
can anyone suggest what else I may be missing?
Or does anyone know what voltage should be going to the coils through the wire harness?
Or maybe if anyone is in the DFW area has a couple hour could help me out this weekend?
*82 Degrees, sun is shining, T-tops are off, windows are down, cruising down the highway at 80 MPH, and the only music I can here is coming from my exhaust... this is what owning a Z32 is all about.*
