TwinTurbo.NET: Nissan 300ZX forum - I fabricated a longer pin coming out of the slave cyl. (n/m)
Gordo 93TT Daytona
on April 13, 2010 at 7:09 PM
Can the movement of the clutch slave cylinder be adjusted?->
posted by Quick_Z
on April 13, 2010 at 10:25 AM
Quick_Z
10:25:34 04/13/10
you probably need to bleed your clutch (n/m)
aliaZ
10:51:57 04/13/10
It couldn't be a bleeding issue, because why would it
Quick_Z
11:03:24 04/13/10
your symptoms describe air in the clutch line (n/m)
aliaZ
11:06:02 04/13/10
Hmm, I've been having similar issues. I've bled the clutch
Wright (Ca)
10:56:52 04/13/10
did you bleed it correctly?
aliaZ
11:11:35 04/13/10
I'll try doing that. Is almost 2 ft enough for "WAY up"? And
Quick_Z
11:16:24 04/13/10
dunno. was the bleed screw the highest point in the line?
aliaZ
11:19:46 04/13/10
didn't you delete your fender bleed screw? (n/m)
aliaZ
11:21:40 04/13/10
I did. The only thing I haven't done is bench bleed the
Wright (Ca)
11:33:06 04/13/10
It sounds like you didnt do the clutch pedal adjustment when
fantomZ(OH)
11:13:39 04/13/10
If you didn't.
fantomZ(OH)
11:19:46 04/13/10
in case you want to delete your fender bleed line
aliaZ
11:23:24 04/13/10
I fabricated a longer pin coming out of the slave cyl. (n/m) -
Gordo 93TT Daytona
19:09:48 04/13/10
