TwinTurbo.NET: Nissan 300ZX forum - I have little to no clutch pressure and im not sure what my
Subject I have little to no clutch pressure and im not sure what my
Posted by Adamo on April 13, 2010 at 5:37 PM
  This message has been viewed 140 times.
Message problem is. Searching showed its likely either my slave or master cylinder. The slave didn't appear to be leaking but there was some rust after i pulled back the rubber boot. I am suspecting that its my master cylinder because i read a post about it sometimes leaking on the inside of the firewall instead of the outside. When i pulled back the carpet near the clutch pedal there was a tiny amount of oil. I was going to try and remove the master cylinder, if i have it off is there a sure way to know if it has failed?
Thanks in advance.
