TwinTurbo.NET: Nissan 300ZX forum - People are going say "Delete", However...
Subject People are going say "Delete", However...
Posted by Draker (Eugene, OR) on April 13, 2010 at 4:34 PM
  This message has been viewed 96 times.
In Reply To EGR valve makes check engine light come on posted by krob19111 on April 13, 2010 at 03:00 PM
Message check the operation, make sure it's opening correctly with a vac pump. Likely it's getting stuck, or the temp is throwing the code. It's likely a delete would be a good option because you might have to pull it to fix the problem anyway. You might be able to just disable it and use the resistor trick to stop the code from being set.
