TwinTurbo.NET: Nissan 300ZX forum - I just use vaseline on O-rings and rail,the injector will
Subject I just use vaseline on O-rings and rail,the injector will
Posted by Quick_Z on April 13, 2010 at 3:36 PM
In Reply To Defective (brand new) injector? posted by someotherguy on April 11, 2010 at 11:04 PM
Message slide into place with almost no effort, and I can actually take it back out again from the top with almost no effort. You must use enough vaseline on the O-rings though, on both of them, otherwise it won't be easy to install the injector, and due to how sticky the rubber O-rings are, pinching or tearing them is easy, with enough lubrication you shouldn't have any problems. Try replacing both O-rings on that injector and try again with vaseline on both the top and the bottom this time.
