TwinTurbo.NET: Nissan 300ZX forum - Brake bleeding problem
Subject Brake bleeding problem
Posted by RevHard on April 13, 2010 at 12:34 PM
  This message has been viewed 85 times.
Message Ever since I replaced the brake piston seals (they were leaking), I could not bleed the air out.
I tried bleeding 3 times following the proper order. The pedal still goes down all the way to the floor. I have steel braided lines.
The system has no visible leaks and fluid level is not dropping over time.
Any similar experience or clues?
