TwinTurbo.NET: Nissan 300ZX forum - Odd Clutch noise, Clutch disc question.
Subject Odd Clutch noise, Clutch disc question.
Posted by Josef(Houston) on April 13, 2010 at 11:32 AM
  This message has been viewed 137 times.
Message Hey guys,
I had a quick question.
For reference: I have had the Stage V Southbend SS full face
clutch for about 15K miles now, and has lots of life left on it.
A description of the noise i have: when i put the car in gear to
start moving and I let go of the clutch pedal, there is a short
grinding/rattling noise i can hear, and it goes away when the
clutch in fully engaged. It only happens in lower gears, or
when i am going 20mph and have it in forth gear and hit the
gas.
I recently pulled the tranny out to change out the reverse
sensor switch on the transmission. I also replaced the pilot
bearing while in there (which was a possible suspect for the
noise). I also greased up the clutch fork, input shaft, pilot
bearing and stuff with moly fortified grease (another suspect
since i had used white lithium grease previously).
So now i think i pinpointed the problem:
My question is, When the clutch disc is out, are the springs in
the clutch disc supposed to move at all? I recall one of the
springs could be moved around with my fingers and made a
rattling noise if I shook the disc around. I dont think this is
normal. I dont have a new clutch disc laying around to check
if those springs have any free play.
Thanks for your time!
src="http://i141.photobucket.com/albums/r70/josefweber/PICT28
22-1.jpg">
src="http://i141.photobucket.com/albums/r70/josefweber/736823
c0.gif">
