TwinTurbo.NET: Nissan 300ZX forum - Yes it does. The fuel rails need to be pressure >>>
Subject Yes it does. The fuel rails need to be pressure >>>
Posted by ZUL8TR on April 13, 2010 at 7:00 AM
  This message has been viewed 153 times.
In Reply To this makes me wonder, what does one do to avoid this? posted by KasbeKZ(VA) on April 12, 2010 at 11:10 PM
Message tested at about 50 psi in a closed loop condition before starting the engine to make sure the O rings have seated properly. This can easily be done with the fuel rails on the car with the plenum in place. If a plenum and fuel rail pull the loop test needs to be done to the fuel rails before installing on the engine and this also allows the tip of each injector to be visually inspected for leaks.
ZUL8TR in Orlando,FL
