TwinTurbo.NET: Nissan 300ZX forum - damper and FPR are kinda maintenance items
Subject damper and FPR are kinda maintenance items
Posted by KasbeKZ(VA) on April 11, 2010 at 9:58 PM
  This message has been viewed 85 times.
In Reply To Fuel Leak Cause Rough Idle? posted by paul1994 on April 11, 2010 at 09:10 PM
Message replacing them on cars with some miles on them (roughly around 60k and up) will yield good results. at the same time, if there's no problem anymore, there's not any real reason to worry about it.
i would, however, recommend replacing your fuel lines. those aren't really expected to last forever.
i'm not sure if small fuel leaks can cause rough idle, but i do know that vacuum leaks can. is there any chance you fixed one of those at the damper?
