TwinTurbo.NET: Nissan 300ZX forum - Re: HELP!! No clutch pressure and disegagement
Subject Re: HELP!! No clutch pressure and disegagement
Posted by 2inTurbo on April 11, 2010 at 11:43 AM
  This message has been viewed 119 times.
In Reply To HELP!! No clutch pressure and disegagement posted by 2inTurbo on April 11, 2010 at 11:37 AM
Message :My clutch will not disengage and the clutch pedal feels loose or soft,
:another thing is that the trans won't go in gear whenever the engine is
:running(it's fine with the enige off so I know it's not a trans problem) it's
:like I'm not pressing the clutch. And whenever I try to start the engine in
:gear it stalls out right away.
:Ok here is what led to this: I replaced the clutch and the flywheel.
:I felt the pedal after and it was nice and stiff but then I bled it and it
:went completely soft with no pressure, I bled it just like you bleed
brakes
:SORRY I MEANT TO SAY open valve-pedal down, close valve-pedal up.
I'm thinking maybe I blew
:the seals in the master or I bled it wrong so that I trapped a lot of air in
:the system. I'm hoping it's that and nothing mechanical.
:Thanks for any help
