My clutch will not disengage and the clutch pedal feels loose or soft, another thing is that the trans won't go in gear whenever the engine is running(it's fine with the enige off so I know it's not a trans problem) it's like I'm not pressing the clutch. And whenever I try to start the engine in gear it stalls out right away. Ok here is what led to this: I replaced the clutch and the flywheel. I felt the pedal after and it was nice and stiff but then I bled it and it went completely soft with no pressure, I bled it just like you bleed brakes pedal down-open valve, close valve-pedal up. I'm thinking maybe I blew the seals in the master or I bled it wrong so that I trapped a lot of air in the system. I'm hoping it's that and nothing mechanical.
Thanks for any help
HELP!! No clutch pressure and disegagement - 2inTurbo11:37:51 04/11/10
