| I am helping a friend upgrade his tt's tune. We want to use a spare ECU he has but it is from an NA. I have seen discussions where the NA ECU will work OK with some minor issues such as fuel pump speed etc... I socketed the board and installed my emulator with a tune for my car then installed the ECU in my car to be sure it worked OK. My car has the boost solenoids removed and replaced with an indicator light/relay so I can tell if it is in safety boost mode. With the NA ECU the lamp is on all the time. Is that normal or is there a problem with the ECU?
KKROFFTNow occurs everywhere, simultaneously. But it doesn't have to be experienced the moment it happens. Every now that ever was is still exactly when it was, when it was now. Then, in terms of perception, is nothing more than all the nows that are no longer now. Thus, the difference between now and then is when. --The Waystoppers Users' Manual
