TwinTurbo.NET: Nissan 300ZX forum - maybe this willl help . one of the two lines coming
Subject maybe this willl help . one of the two lines coming
Posted by xteam300tt on April 08, 2010 at 11:23 AM
  This message has been viewed 355 times.
In Reply To I should clarify: posted by ooofoo on April 08, 2010 at 12:19 AM
Message through the passengerside is the aiv vacumm line and the other is your front windshield washer fluid line . make sure you get them right or you will inject water into your engine when you turn on your washer . the washer line will run in the fender all the way to a small pump by the front pass side turn siginal . hope that helps
