TwinTurbo.NET: Nissan 300ZX forum - Re: AIV hose drilled?
Subject Re: AIV hose drilled?
Posted by jeff1954 on April 08, 2010 at 3:06 AM
  This message has been viewed 94 times.
In Reply To AIV hose drilled? posted by inf on April 08, 2010 at 02:04 AM
Message Drill a small hole (1/8 or 3/16s) in the lowest corner of the plastic filter housing. Don't drill into the hoses. Good time to change the AIV filters & clean the reed valves (they will be plenty nasty). When you're done, the gurgling will be 99% gone, but you will occasionally have a small water puddle on the garage floor where the car has been idling. Not much during hotter, dryer months. Disassembly tip: grab the four square nuts that hold the filter box together with pliers or they will just spin & chew up the plastic. They're always corroded.
