TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Clickity, clackity sound from front suspension
Subject Re: Re: Clickity, clackity sound from front suspension
Posted by bnhunt on April 07, 2010 at 9:23 PM
  This message has been viewed 81 times.
In Reply To Re: Clickity, clackity sound from front suspension posted by jaidieray on April 07, 2010 at 06:03 PM
Message Well he said the passenger side rear was missing the shims and could cause
this noise. Which I plan to fix now that I know they are missing. However
the sound is very clearly coming from the front. I replaced the front brakes
and rotors myself about 4k miles ago and one side did have one less shim
than the other. Noise just started a few days ago though. Think the shim
could be the cause? Also, it makes the noise while coasting, not just when
applying the brakes.
To the other reply, it is an all stock suspension. I'm sure he checked those
things, he said he checked anything that would generally cause this.
:If you dont have these installed it will cause a clunking when you press on
the brakes. Last time i had to buy these i got the front and rears on the
bay.
:[ HREF="http://www.z1motorsports.com/product_info.php?
products_id=4285">http://www.z1motorsports.com/product_info.php?
products_id=4285
